TwinTurbo.NET: Nissan 300ZX forum - What is the water / coolant mix you are running? (n/m)
MixManMash
on September 29, 2020 at 9:30 PM
Re: How clean are the fins for the radiator and for the AC
posted by dancefloor
on September 29, 2020 at 06:24 PM
Datascan says my coolant temp is 107 degrees. 95TT manual.
dancefloor
12:43:53 09/29/20
How hot is hot?
platinumist
14:58:04 09/29/20
its 95F outside. Re: How hot is hot? (n/m)
dancefloor
18:28:48 09/29/20
MixManMash
17:04:00 09/29/20
dancefloor
18:24:28 09/29/20
What is the water / coolant mix you are running? (n/m) -
MixManMash
21:30:49 09/29/20
50:50 Re: What is the water / coolant mix you are running?
dancefloor
10:54:47 09/30/20
There isn't a "factory setting" as you adjust based on your
MixManMash
13:27:55 10/03/20
dancefloor
10:55:17 09/30/20
found a tiny leak Re: Datascan says my coolant temp is 107 d
dancefloor
12:53:18 10/07/20
Re: found a tiny leak Re: Datascan says my coolant temp is 107 d
Ts2
15:17:34 10/09/20
